I own a new 2006 240 Sundancer with the Bravo 3 outdrive. I have owned many boats, but this one is very instable. At speed, the boat will list to either port or starboard, and the trim tabs have to be constantly tweaked to keep the boat level- Without constant attention, the boat will tip to one side and the severity of the list makes it feel as though the boat will tip over.
The only way to stop the tipping is to back the boat down to where is it barely on plane.
This condition is much worse as the gas tank is emptied through normal use- below half a tank, it is much worse.
I purchased a Stingray Hydrofoil piece for the lower unit, but it did not help to correct the problem.
This past weekend on Lake Michigan, in following 3-5' seas, it was a nightmare with every larger swell seeming to tip the boat.
I am interested in anyone's suggestions as to how they have resolved the problem....
Thanks
Thanks
