Tach/Rectifier question
dnyhuf
1992 Johnson 200GT. When I purchased the boat this last spring, noticed that tach was erratic. Initial investigation showed burnt ground wiring from key switch to tach. Found loose main ground at starter and tightened. and replaced burnt wiring. Tach still erratic and finally quits alltogether. Read Joe Reeves tach test and tach does not work on yellow/grey or yellow, so I think bad tach. Decide to check charging before I purchase parts, and lo and behold rectifier/regulator shows bad. Do I need to replace both tach and rectifier, or replace rectifier and recheck tach?:confused:
Joe Reeves
Re: Tach/Rectifier question
If you've checked the rectifier properly and found it to be faulty, replace that item first, then recheck the tachometer.
dnyhuf
Thanks Joe, the rectifier fixed everything. Any explanation why the tachometer didn't work off of stator?
wilde1j
The stator generates AC ... the tach works off DC pulses from the rectifier output.
