Starting problem
jdtower23
Preparing to start my motor after head gaskets, etc. and of course now the ignition switch won't crank it...I took a screwdriver to the solenoid and it cranked strong....turned the key on and getting power but nothing when i try to start......
I just replaced the ignition switch thinking that was it but same result....
Wires seem tight on the starter....where should I check, test 1st?
Thanks
jdtower23
Re: Starting problem
Did a little testing tonight....switch is fine....no power on the solenoid or "s" wire at the slave cylinder when trying to crank...
Where should I proceed next? bypass the neutral safety switch? If so, how difficult is this on an OMC?
Thanks...
Get a Test Light,+ Follow the Power................
Then you'll Know where the Issue is, instead of Guessing..........
Don S
Which solenoid????
What is the "S" wire at the slave cylinder, the slave solenoid???? or since you say cylinder, are you refering to the cylinder shaped solenoid mounted on top of the starter?
jdtower23
Sorry, was tired....meant slave solenoid....I tested for power at the slave solenoid at the yellow/red wire on the slave solenoid while key was in start position....the one hooked to "S" on the switch....
jdtower23
What do I do now? I've traced the "s" wire....it's split into a double black wire....looks like it ends up at the rear portion of the throttle....only one of the black wires is spliced near the switch....it comes to 2 wires and the other wire I haven't figured out where it goes yet.....now I know I'm in over my head.....
jdtower23
OK, I checked for power on the 2 lines coming out of the throttle....one has power, the other doesn't....is the other line the one coming out AFTER the neutral safety?
Thanks
Don S
THINK about it. You have power coming into your neutral safety switch, but it doesn,t come out......... Question is, why. Does the switch activate? Does the switch WORK, are the wires hooked up to the switch. Is the switch loose, or out of adjustment, did you look at it, did you check anything????
jdtower23
Don,
Can I hook those 2 wires together to bypass it? I just want to try to start it and then figure that out later or even take it to the marina....
Thanks
Don S
Don,
Thanks
That is what I mean about THINK!!!!!
A neutral safty switch is just that, a switch. It's either ON or OFF. If you hook the wires together it's the same as turning the switch on which is the same as having the shifter in neutral.
You can then start the engine because power is getting to the solenoid.
jdtower23
Well it was the neutral safety switch....bypassed it and the motor cranked...do I have to disassemble the whole throttle to replace it?
mo2380
Just following your post, I will be starting this step by step later this evening. Don thanks ahead of time for posting this information.
