TonyNoriega
Thread starter- Joined
- Jul 31, 2007
- 100
Scenario: Fished last evening for 4 hours - ran engine 1/2 hr of that time. Nav lights (bow only) on while anchored and fishing. Then engine wouldn't crank on starting battery so I switched to trolling deep cycle and it cranked fine.
My GPS/Sonar displays voltage and after cranking/running it was reading 14+volts, going higher when running higher rpm's. With my limited knowledge I believe that means that the stator is generating power ok.
This morning the starting battery reads 12.07v on my multi-meter. The purchase date for the battery is Feb 07.
I have two concerns: that the battery ran down with such little drain in a relatively short period, and secondly, that my 200hpdi wouldn't crank with 12.07 volts.
I certainly would appreciate your opinions.
