rpm at idle
brian3127
what should the rpms be at when engine is a a idle?
i get it to about 1,000 before it stalls. should it be lower?
rickdb1boat
Re: rpm at idle
650-750 in gear, on the water, would not be out of the ordinary, depending on which engine you have...
brian3127
Re: rpm at idle
so i should set low speed while it is in gear and not in nuetral
rickdb1boat
Re: rpm at idle
Yes. Set it to specs while on the water, in gear and underway (Not tied to the dock)....
