1992 Johnson 60
jroberts17
The top cylinder's piston in my engine had a hole burnt in it and i am fixing it myself. I need to know the torque specs for putting it back together. It is a 1992 Johnson, 3 cylinder, 60 horse, model TJ60TLene. I am replacing the oil seal because my friend said that might have been the problem. Any other ideas as to what could have caused this??
Thanks for any help or advice.
dreamchaser
Re: 1992 Johnson 60
OK i,ll bite........hole in the piston ? Im thinkin heat or detonation . hows the cooling system operatin? Ur local library can supply a manual to help ur get those numbers right, GOOD LUCK ......
