I've got a mid to late 60s Evinrude Sportwin 9.5 hp outboard motor with carb troubles. I've tried two different carbs. One has a high speed issue, where it wont open up all the way, about half max, and the other has a low speed problem.
The one with the low speed problem seems to me the most likely candidate to fix. Ive tried two different low speed mixture screws and no matter what I do it just does the tunking thing and stalls out below about 1500 rpms or 2000 or so. I took the guts apart and blew all the jets out and cleaned it up real nice, and cleaner flows through all the ports effortlessly. The needle, float, and seat all look really good and appear to be brand new.
Air flow is not a problem because the cowling is off while testing. It does the same thing in a barrel as it does on the lake. You can fool it and get it into gear by using the choke but it still surges till you get up to full throttle where it runs fine and has plenty of power.
Anyone have any idea what I could do to fix this, or have a carburettor they wish to sell? If so reply/pm/email. Email = ffcpross at verizon dot net.
Everything is as it should be on the linkage between the ignition plate and the throttle as well. Its identically to a motor I had about 4 years ago, opens up and moves the same way and everything. I have also swapped in a set of good known coils, points, and condensers to rule those out as well as new spark plugs.
