iwannagofast
Thread starter- Joined
- Jul 26, 2007
- 42
Had my 73 135 evinrude out on the lake this weekend to try and do some trouble shooting for my horse power issues and this is what I found.
With the lid off the motor and under full throttle it seems that my top two cylinders are receiving a steady stream of fuel from the carbs. On my bottom two cylinders only one is receiving a nice flow of fuel and the other one is barely getting a sputter. I tore the carbs off again and made sure they were all clean and also that the tube from the bowl that feeds the fuel upto the cyl was not blocked. For some reason fuel just does not want to flow up that one tube.
Not knowing too much about this stuff just sort of figuring it out maybe someone can tell me what might cause this to happen? What exactly causes the vacume that is required to pull the fuel up through that tube in the carb?
Just a note if I have someone sit at the back of the boat and feed fuel using a spray bottle directly into that one cylinder the motor cooks I mean if the boat had wings it would fly out of the water.
