ReelSmokin
- Joined
- Aug 8, 2007
- 6
I have a 115 Mariner inline 6. Recently I had the stator replaced and the engine ran great. After 4 trips I lost RPM and now only top out around 4200 but only under load. In dry dock I can redline it up to 6000. Even in the water at 4200 it sounds good, no misses, vibration, or jerking. I checked fuel by spraying gas into carbs while at top RPM and engine bogs so I iliminated that. (By the way dangerous) I checked all the pulgs, none seem to be burnt and all had a little wetness to them which is normal. Good compression in all cylinders as well. I have run out of things I know to test. Any suggestions.
