120 hp to 4.3 l swap - some info needed
UncleBomb
Re: 120 hp to 4.3 l swap - some info needed
I'll second Iron Maiden. There are so many cheap boats out there. I bought one and the voltage regulator went. $400 to replace/modify. :eek:
Listen to these guys. There are reasons for everything. Not just "Let's make it expensive for marine guys.:
You aren't the first to come up with this brilliant idea.
Remember, if it breaks, there's no where to pull over. :D
GiMLit
Hey I liked Maiden back in the day and still will listen to it if it's on!
I ditched the idea of the 4.3 and the idea of staying with either of the 4 cylinder engines that I have.
I chose instead to go with a 3.8. It's a complete package that I removed from a running boat.
Thanks for your 2 cents tho. Appreciated.
