Last weekend I took the boat out and tooled around the lake for a while. We pulled into the marina for lunch, and when we returned the motor wouldn't go into reverse. It had been working fine until then. Tonight, I pulled off the cowlimg to run the voltage and ohms test I found in another thread by J.Reeves. I noticed I had a fuel line leaking, so I took all the fuel lines off to replace them. Then I did the tests. Results were as follows.
In neutral, green to ground - 12V...Blue to ground - 0v
In forward, green to ground - 0v...blue to ground - 0v
In reverse, green to ground - .45v...blue to ground - .45v
both blue and green 6.3 Ohms to ground...green to blue, 12 ohms.
Does the engine need to be running to do these tests? If so, I will do them again in the morning after I replace the fuel lines. If not, where should I start looking for the problem? Thanks for any help.
