Re: 1975 75hp evenrude water in gear case
Good evening, one way to check for leaks is to lightly presurize the geargox with compressed air while the gearbox is submerged in a tank of waters,(also see handbook/workshop manual) if you see air bubbles then you have a leak. Replace the seals, also check oil filler and oil drain plugsfor leaks.I have just done a seal replacement job on my gearbox all the seals as well as water pump impellor were replaced, ,Regards Willie Wright
