exhaust steam?
mille73
My port engine crusader220 runs at around 160* the starboard engine runs 140* I switched temp sending unit wires & the temps switched so I would say the gauges are pretty accurate. Last night very calm seas was out for a short cruise, the port engine looked like their was steam in the exhaust wake?
What should I be looking for. I have no idea how long or if the exhaust manifolds are origional equip. The boat is a 1979 Carver with 800 hours.
thrasher
Re: exhaust steam?
I would suggest looking at the thermostats. If the temperature of the engine's are remaining constant, I would suspect the 140 engine has the wrong thermostat or a defective thermostat.. Neither temperature is indicating a damaged engine, but 140 seems a little bit low..
Seeing steam in the exhaust wake is very difficult to judge (difficult to judge if it's really steam or something else), it could be a small amount of vapour from condensation, it could be the engine burning a slight amount of oil, it could be water in your gas that is causing it..
The easiest thing is to start with the thermostats and go from there.
Gary
mille73
Re: exhaust steam?
I changed stats last year (marine oem parts) no change in engine temps. I just changed plugs wires cap & rotors. The plugs in the port engine were dirtyier then the starboard engine. No change in temp with new ignition parts.
thrasher
Re: exhaust steam?
Maybe it's the temerature sender unit (the part that screws into the engine near the thermostat)? Have you tried swapping them over? I see that you swapped the wiring for the gauges. You seem to have done everything else I can think off.
MikDee
Banned
Re: exhaust steam?
I seem to remember all the I/O marine thermostats were 140 degrees standard. That's where these street racers would get them from when they put a racing chip in their cars calling for a cooler 140 degree thermostat. So your marine engine should run 140 degrees.
tommays
Re: exhaust steam?
The 140 OPENS at 140 and would be full open at TEMP X it would have to run at least in the 150 to 160 range if it and the gauge were correct
The gauges are not that accurate ,there just a reference point if something goes wrong
Tommays
