QUESTIONs ON TESTING A VERNATHERM
shipwreck
I HAVE 1967 evrinrude 60 hp sport four model 60733
QUESTIONs ON TESTING A VERNATHERM:
Can VERNATHERM be tested like a regular thermostat by put in hot water?
Dose any know what temperature VERNATHERM for is installed in my model 60733?
How do test a VERNATHERM?
rickdb1boat
Re: QUESTIONs ON TESTING A VERNATHERM
I don't know the opening spec for that stat, but yes, it will test just like a thermostat...
shipwreck
i tested in hot water it sprung out and has never reset even in cold water
163 degree and 125degree per manual
F_R
It won't retract by itself. You have to push the pin in.
shipwreck
how hard should be to push pin in?
use vice to push back down?
or by hand to push down?
F_R
Finger pressure. If it takes more, it is corroded in the hole.
shipwreck
do know if 143 degree for my motor?
i found replacement new for 12.00 deal whats 45.00
it has 143 stamped on and b660.. part number
so i believe that 143 degree
