erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
Hi all.
I had an accident with my boat on its trailer where the motor shifted to starboard, shearing two motor mount bolts and pulling two others out.
I've been working on repairs to the whole boat, and today I used a hole saw on a drill to core out around the old bolt holes to removed the snapped off bolt parts. Guess what I found?
Yep, lots of dark brown powder and some good wood. Now, I know the transom is sound because A) I checked it with an awl B) I tapped it with a hammer and C) It withstood enough force in the accident to snap part of the transom plate on the inside and the bell housing on the sterndrive instead of cracking itself. The floor checks out good too, so I'm hoping the stringers either are ok or else will last a year or two.
For the motor mounts, however, I'm going to have to re-core them. I've come up with the following plan: First, use a circular saw and sawzall to remove the fiberglass on top of the old mounts - it's about a half inch thick, I think Sea Ray expects most of the strength to come from the glass. Second, I'll use a chainsaw, chisels, vacuum, and drill to remove the old wood. Third, I'll fill the hollows this creates with a chunk of solid wood bedded in epoxy putty made with wood flour. Alternatively, I could fill the space entirely with epoxy putty and skip the wood.
How does this sound for a plan? Any reinforcements or changes that would be good to do?
Erik
Erik
