iwannagofast
Thread starter- Joined
- Jul 26, 2007
- 42
73 85hp evinrude... Just got the motor running today. New stator on her and seemed to run fine on land with the muffs hooked up. Warm water was peeing out a couple of different holes and blowing out of the two ports at the back of the motor near the top.
Took the boat on the lake for a test ride let her warm up good then gave it some juice went for about a minute or two in one direction at a nice speed slowed down turned around and started on my way back. Part way back it seemed as though just out of the blue while full throttle that I lost all power to the motor, and she just died. She would not crank over either. Took the top off the motor and found the motor to be very hot to the touch. Tried to crank it still nothing although you could see the starter engaging. After about 5 minutes finally she would turn over and start.
On my way again full throttle and the same thing happend. Waited about 5 minutes and the motor would turn over and start. As an experiment I countinued to run the boat around the lake at low speed without a problem. Even at 1/4 THROTTLE no problem but at high end seems like the motor is over heating and locking up.
If the impeller seems to be sucking in the water and peeing it out What could be wrong?
