johnp34
Thread starter- Joined
- Jul 11, 2007
- 30
1988 Force 50 hp - I need to resolve problem One first.
Problem One - Engine cranks slow but I have a new fully charged battery. I am about to replace the battery cables because it appears to be corroded. Next I will check the starter relay then the starter. also - I may lube the flywheel and starter gears. Any suggestions?
Problem Two - The Voltage gauge indicates 12 V. I don't think it is charging. I checked the rectifier and it is fine. Haven't check stator. Hoping the battery cables from problem one will resolve this...
Looking for suggestions...
