Re: Help required for 1981 35hp Evinrude: impeller
If the age of the impellor is unknown, best to change it for peace of mind. Its a cheap thing to change, expensive thing to have go on you, and anyone the fairly mechanically inclined with a basic tool kit can do it. Do you have a manual? If not, you should get one. Bucket wont be enough, best way is a barrel or large garbage can filled with water for testing. Can also use "muffs", but I am unsure if you year allows it, hopefully someone will jump in and let us know. Muffs are simply 2 rubber plungers that a hose attaches to that you place over your water intake to send cooling water to the impellor which sends it to the motor.
