How to remove lower unit?
sabinki
Can someone tell me what holds the lower unit on a 15hp Johnson 1991.I have removed 6 bolts near the foot and loosened the shifter cable near the foot but it still has something stopping it from coming out because I can get it down so far then it stops I have also tried turning the fly wheel while pulling down.
F_R
Re: How to remove lower unit?
Loosened what shift cable? There is a brass shift rod connector with two screws in it, in the space where the gearcase has dropped down thus far. You have to completely remove one of the screws.
gotboostedvr6
i have a 93 15 and have the same problem... any help?
samo_ott
What's the bump for? FR explained it. There's a connector where the LU drops down tad. Undo 1 screw completely and it will come off.
waterman1971
Here is a tutorial that shows the BASIC location of the shift screw. It's sort of a generic location on most models.
Lower Unit Removal / Water Pump installation Tutorial
Good information. Perhaps you guys should have a sticky with pics. I just joined up this morning, so I'm not sure what type of questions you guys allow. I searched for "gearcase removal" and I recieved 500 results. I am going to be doing mine soon. If all goes well I'll put it up.
mthieme
Resist the temptation to pry it apart. I just replaced the impeller on a Merc some jack$ss did that to and damaged the LU.
