1982 johnson 70hp one cyl not firing
loujoe
I am working on this Johnson, two years ago it was rebuilt. Now the center coil is not firing . Tracing the power wire comming from the bus bar to the stator there is 12v, the two wires comming out of the stator have 0v. These wires go directly into a rectangular brown box in front of the coils. Three tan wires leave this box and go directly to the coils. Do these wires carry 12v's too, I cannot get voltage reading on any of the three wires. Yet two of the coils have good strong fire. Jumps 1/2 inch blue streak on my plug wire tester. I have ordered a manual any other help would be greatly appreciated.
Tuna Fish
Dennisanoka
Re: 1982 johnson 70hp one cyl not firing
Can you swap coils and see if the problem follows the coil in question?
loujoe
My plug wires are good I swaped the affected one. Tuna
loujoe
My plug wires are good I swaped the affected one. I will swap coils tomorrow thanks guys. Tuna fish
jtexas
those tan (they should actually be orange) wires from the coils - they carry pulses from the capacitor to the primary coils with a peak of 150V at cranking speed, but you need a DVA adapter to measure it.
here's a pretty comprehensive ignition troubleshooting guide: http://rapair.com/media/Troubleshooting Guide 2006.pdf
I bet swapping the ignition coils gives ya the answer.......
