Volvo Penta Outdrive Problem- Please help!
denwakebdr
I have a 1999 Caravelle boat with a 5.7L GXI Engine. The outdrive is hard to turn under load. Any idea's on what could be wrong? or How to troubleshoot? Please help!:)
Re: Volvo Penta Outdrive Problem- Please help!
Has it been serviced,+ Greased lately,..??....
Does it have Power Steering,..??... Is there Fluid in the Reservoir,..??....
Don S
Along with Bondo's suggestions and questions. Make sure the steering cable coming from the helm isn't tied down. It has to move back and forth while steering. I had one where the guy stacked downrigger balls between the cable and the boat to keep them from rolling around. Really bound up things.
denwakebdr
Thanks for the replies so far. The outdrive has not really been serviced per say, but i did change the gear oil at the end of last season. I checked the power steering fluid and it seems to be okay. I have not greased. There is a zirk(sp?) fitting on the side of the outdrive that i have never greased, would this make a difference. I will check the steering cable to make sure it is not bound, but i have not stored anything on top of it. I am not sure where the reservoir is? Any suggesstions?
denwakebdr
I have gotten a few replies,. but still no answer! Please, can anybody help!
Scaaty
Get in there and grease the zerks (any and all involved in the steering), then do a little cranking back and forth --repeat.
