Evinrude 6 Fisherman
mmg123
Hi to everybody here .
I have a evinrude 6HP FISHERMAN 6002B B 18561 i dont know the year of it those are numbers on a side plate on shaft also same on engine block stamped on a disc core plug. I have a problem with the motor i have only just bought it 2 mths ago but the guy i bought it off had it serviced 8 mths ago since then its been stood .Till yesterday i took it out for a test run on my boat it was hard to start at first but i eventully got it to run the problem is i stopped it to anchor up the it would not start for a while eventully it did. Once i was back in harbour i did same thing then tried to restart but no joy at all this time i gave up.Also i did find it will not tick over i had to keep revs on and it would only start on full throttle not in the start position as marked on the revs arm. Can someone please advise to where the problem lies:confused: . Thank you
freddyray21
Re: Evinrude 6 Fisherman
not sure of the year either. I think the B might mean it is a Belgium motor. My 65 fisherman did the same thing. Turned out it was a sticky carb float. The old floats did not have the clip to hook the needle valve to the float and mine was sticking closed. I rebuilt the carb with a new kit and clip and it was fine after that.
F_R
It's a 1970. Probably has bad (cracked) coils. At least that's the first place you should be looking....After a compression test. Is the paint burned or discolored on the head? Check back if that isn't the problem.
mmg123
Thank you for your replies No there is no burnt paint on head its as new . The compression is ok to it ran and push boat threw the water no problems on a 11ft firberglass body loaded with 3 men and gear. I have had another look on serial plate and it is a belgium motor . Do you still think coils it was fully serviced 8mths ago and ran ok then also its been stored inside.:confused:
F_R
Do I still think coils? Well let's just say I would be looking there. Since it is a 1970 it is kind of an educated guess. If it were a couple of years older, I would say absolutely. It is age that gets them. They kept making changes to the coils' covering down through the years to try to prevent the problem. It is 37 years old you know. Past history got nothing to do with it.
mmg123
Thank you captain for your reply yes it was the coils cracked replaced them and engine runing now starts first time but got another problem now . The engine will not tick over i have to keep 4revs on or its stops also you would know the fuel mixture with oil would you i have at the moment mixed 500ml with 25 litres of fuel and it seem very oily in test bin .Regards mmg123:confused:
F_R
If you cannot adjust the slow speed needle and get a satisfactory idle, you probably will have to clean the carburetor. That is not the only possibility though.
I am totally ignorant concering metric measurements. The mix is 50:1, however that translates. Here in the swamps it is 1 pint of oil to 6 gallons of gas.
