NEW POSTER cant get a response
glbudman
this forum is great lot of knowledgeable great advice.but cant get a response to a linkage adjustment question.ok here we go i have a 1998 50hp evinrude 2stroke model#e50tslecc i replaced the water pump now trying to put lower unit back on the shifting linkage doesnt go all the way back down to the screw/pin hole took lower unit off in nuetral is this right i guess what i want to know what exactly do i do. im a rookie thanks in advance. P.S selling boat trying not to buy manaul tight funds. thanks again.
fire831
Re: NEW POSTER cant get a response
I don't know what your shifter rod looks like but mine on my 1978 85 hp Evinrude has a angle and it goes towards the front of the motor. Also I had to move my shifter alittle to get mine to line back up. Hope this helps. Do you have a manual?
Molaker
The length of the shift rod is critical AND adjustable. Did you turn the shift rod when you had it apart? If the shift rod length is correct and the gearbox is set to neutral and the shift linkage in the neutral position, the hole should align. I don't have a book to tell me what the shift rod length should be for your motor. Perhaps someone else does. Otherwise, make sure the gearbox is in neutral, disconnect the shift cable so the linkage moves freely and you should be able to align the hole.
glbudman
My Linkage Rod Comes From The Top Of The Motor Havent Been Back To Check To See If I Can Pull Down On The Rod. How Do I Know If My Gear Box Is In Neutral. Thanks For Your Reply.
ezeke
If your gearcase is in neutral, the propeller will spin freely.
OhWellcraft
When I did mine the first time I had a tough time getting it to line back up. The main thing as asked above did you turn the shift rod itself? By turning it you change the length either longer or shorter. It MUST be at the exact length specified or it will never function properly. If you didnt turn it at all you should be fine to bolt it right back up. If it has an angle on the top (7) kind of like that it goes toward the front(bow) usually on mine I will put it in reverse before trying to remove the linkage bolt as this gets it into a much better spot to remove the bolt/pin. Once removed the mounting bracket will move a little so I have to have someone move it (control lever) ever so slightly to help it line up. The main thing is NOT to turn the shift rod. If you look close you can see about 1/2" of the shift rod exposed under the motor cowl this is a good place to grab it with some long needle nose pliers to slightly turn it if need be to line it up better. Also you can take a hanger and bend it to fit through the mounting bracket and through the shift rod to help line it up while you get the bolt/pin ready to reinstall. a long 1/4" extension with the bolt taped in really helps with the reinstall. Good luck and keep at it can be a real bear sometimes. If you did turn the shift rod a few full turns one way or another you will need to get that adjusted back to spec before you install the lu. I dont have the measurement for your exact engine but I'm sure someone here would and could tell you exactly how to fix it.
glbudman
thanks for your replys at the bottom of the shift rod has a forked thing with hole for pin it swivels around for adjustment yes and of course i messed with it before i realized i shouldnt have. tommorrow ill try your ideas thanks again.
gejandsons
Put the shifter in forwad & see the direction of movement on the rod. Put the gear box in forward by moving it in the same direction. Then you can turn the prop to align the splines on the drive shaft.
glbudman
called the marina to see what they would say. they siad i screwed up big time i should have never unscrewed the screw/pin from the gearcase should have been disconnected from top. now they say the lower unit has to be taken apart plus put in new seals to get this job done. is it that hard to do myself im a rookie. they want $ 335.00 to do this job. cant afford that. hope someone can help. thanks
Molaker
Well, now you've done it...:) You'd better up your intended sale price about $20 and get a manual. It can be done fairly easily without a manual, but you can already see how much trouble you can get into if you go by "instinct". Plus, the manual should give you what you need to readjust the shift rod length.
glbudman
hi and thanks for the reply your right dont want to screw up again going to order a manual. thanks again.
