Singing Boat Guy
Thread starter- Joined
- Jul 22, 2007
- 47
I was at the lake yesterday and anchored a couple of times and shut the engine down to relax and listen to some tunes on the new stereo I installed. On the last time I started up and hit the throttle, got up on plane and was accelerating when she started losing power. I could pull back and get some stability, but it would always seem to cut out if I gave it more throttle. I brought it to the dock and looked everything over, seeing no obvious problem I went back out to see if the problem persisted and this time could not even get on plane.
The boat is my 1976 Sea Ray with the OMC 175 Inboard.
It revs fine in neutral, but under load it seems to cut out.
When I went to start the boat first time around starting off the day, I hardly had any cranking amps, so I went to check the battery and burnt my fingers on the battery terminals they were so hot. Got them off and changed to my other battery and all seemed good.
The only change was me installing this stereo, which leads to my questions.
1) Can low battery power cause the power problem that I had trying to accelerate?
2) What could be the cause of the battery terminals being hot enough to burn living skin from my fingers?
