Re: 1962 johnson 28hp likes to buck
24:1 regular 87 octane gas to TC-W3 outboard oil. The oil ratio won't cause it to "buck".
Just to clarify, it feels/sounds like you've hit something and not like the powerhead of the motor is miss-firing, right? If it seems like its missing then check your coils. You could very well have a bad ignition.
However, if you hear an audible clunk and the motor feels like it engages/disengages then I'm with TD. It could be the clutch dog. Its easy to fix, but the parts can be expensive. A diagram of a 1959 Big Twin lower unit is included in the following link. It should be the same as yours.
www.myfishingpictures.com/showphoto.php?photo=130961
Pull the skeg and check the lobes on the clutch dog (#20). The lobes should be nice and square (90 degrees) along the edges. Here is a picture of a clutch dog from a 1954 Big Twin.
www.myfishingpictures.com/showphoto.php?photo=130256&sort=7&thecat=500&password=
TD gave you a link on how to set your carb. Use it to set your carb before you attack the lower unit. Also check your coils. There is no sense trying to set your carb if you have bad coils.
