Re: 1962 johnson 28hp likes to buck
great thanks guys i will try that gonna put boat back in the water today and see if i can tune it up........i was unsure also but when i set the high idle mix do i have to do it in gear at full throttle cause if this is the way i have to do it i wont be able to do that cruiseing down the lake hahaha
also i seen in anouther post that was awnsered by td that a 69 johnson does not pee out the exaust is this the same as mine......cause now that i have changed the impeller i get alot of water out but in drops and mist also which i really beleive is a whole lot better than none at all.
also i guess my motor does not have a chargeing system on it when hooked up for an electric start.......i have to manually charge the battery at the end of the day but i am hopeing that i am maybe missing some wires to the battery
thanks guys
DREW
thanks guys
DREW
