Well, maybe it is. I had the boat out last weekend, was running great. Stopped in a little cove for a swim, then when I restarted it, it ran long enough to get it in gear, then it died. Used starter fluid, ran, but didn't appear to get gas. Got towed back, took it home. Pulled the gas filter, looked clear. Pulled the carb bowl, gas was clean, and bowl was full. drained the bowl, cranked it over, bowl filled back up. I blew some wd-40 thru the pickup tube in the bottom of the carb, pulled the main, and air screw, seemed clean.
Still using the original metal can, don't see any crud in it, and the gas is clean up in the float bowl.
Seems like it should run. Still starts on stater fluid...
