new boat owner things to check?
drrtydog
What are things i should check to make sure are ok before using the boat? And how often do these things need checked? The boat i bought was a 67 Alpex 16 footer runabout with 80hp evinrude. Another i have not found a for sure on is what are necessary to have on the boat. Whistle, fire extingusher?????????? Life jackets a must or not? Im in Iowa and will be only on lakes.
Re: new boat owner things to check?
Make sure the plug is in.
Make sure you remember to bring the keys.
when was the impeller last change, you don't want to run hot and burn up the motor. also everytime you start the motor notice that the pee stream is peeing. if not shut it down, and call for help.
RWilson2526
Check your battery before you get to the ramp. sitting on the ramp with a dead battery is pretty embarrassing and somewhat annoying to those behind you.
JimMachinery
It's always a good idea to check the air pressure in the tires and carry a mounted spare, jack and lug wrench that actually fits the lugs.
When were the bearings last repacked? If there are no bearing buddies, they are a cheap investment to improve the life of the bearings. Check at least annually.
Check the trailer lights before you leave on every trip. Simple wire brushing the terminals will solve many problems.
Safety equipment seems like a pain - until you need it! Also, if the coasties board, it makes a favorable impression.
Is the gas tank full? There is often gas available on the lake for a small ransom, but having no gas at the ramp can be embarrassing!
Before I pull out of the driveway, I make sure safety chains and tie downs are in place. There's more, but a lot of it is often learned the hard way...
Best of luck
QC
Bilge pump, Steering, Clean Fuel
Everyday
Sound making device, fire extinguisher, simple tools, spark plugs etc.
craig240DA
Not sure how this will look but it is my checklist for boating.
DESTINATION: __________________________ DATE: ____________
□ Drain plug installed □ Navigation charts for trip
□ Enough fuel for trip □ Weather forecast - safe
□ Float plan given to friend or relative □ Binoculars, Spotlight, camera
□ Food, Drinks □ Tools, Manuals
IN THE WATER, BEFORE BOARDING PASSENGERS OR STARTING ENGINE
□ Equipment stored and balanced □ Oil Level
□ No gas smell in engine compartment □ Gear Oil Level
□ Bilge pump check □ Battery switch Both Batteries on
□ Bilge blower on □ Radio and navigation equipment functioning
□ Engine Visual Inspection □ Navigation Lights on board
□ Steering Fluid □ Registration on board
□ Check Anchor □ Distress Flares in date
□ Close all cabin windows/hatches
PASSENGERS
□ Wearing PFDs, One for each passenger w whistle
□ Seated properly, lookout assignments
□ Safety instructions, Flairs, PFD location, Fire Extinguishers, Radio, Throw able PFD, Waste
STARTING ENGINE
□ Bilge blower on for at least four (4) minutes. □ Shore Power Disconnected
□ Gear shift in neutral position. □ Stern Drive Down/in water
□ Turn Off shore power at breaker □ Start Engine
UNDERWAY
□ Check surroundings □ Check all Gauges
END OF TRIP
□ Equipment dry and stored. □ Shore Power Circuit on/Battery Charge On
□ Electronic equipment and switches off. □ Notify person who had float plan.
□ Battery switch on Both □ Boat covered properly
□ Connect Shore Power □ If boat is out of water, drain plug removed.
drrtydog
thanks for the helpfull replies we took it out today and tubed a bit. I didnt pull the pin out that locks the motor down. Stuff like that plus i was more worried about fluid levels in the motor i mix gas and oil so that is ok. It was fun and for the prop i have a spare that has some knicks out of one propeller and the one on the motor looks good. Only got it half throttle the waves were rough today.
PowerAddict
by impeller, do you mean the waterpump in the lower unit?
If not, then what?
ziggy
yep, that's what he means.
ya could also get a oem servcice manual for yer engine. it'll have lists of items the engine wants to have checked out periodicly and how often ya should be doing those checks......
