championandy
Thread starter- Joined
- Oct 26, 2006
- 4
I have an '84 Mercury Black Max 150. Since I bought the boat 2 yrs ago the speedo hasnt been working at all. I have a pretty good understanding of how the speedometer works. I am a little unclear as far as the pickup goes. I am assuming that the pickup hole is the small teardrop shaped hole in the leading edge of the lower unit. I have located the line that goes from the lower unit to the speedometer in the dash. I took the line apart at a splice about midway up the motor and blew air in it. It is unobstructed and the speedometer will move with air pressure applied. From the splice down to the lower unit is where I am confused. I took the lower unit off and the tube is not connected to the hole I asssumed was the pickup. It is attached to a threaded nylon fitting that screws down into the lower unit. What am i missing here? What is this fitting for? Is something hooked up incorrectly?
