Re: 1989 88 spl Evinrude
I used to have the same Motor. It is my understanding that you must have taken off the heads and serviced the block. Are you absolutely sure you placed the rubber water diverters in the correct position in the water jackets? Also, did you clean out the passages with a soft wire brush before you re-assembled? It sounds like the motor was used in salt water, and perhaps it was neglected and not flushed out; Consequently, salt may have built up and clogged the water passages.
Also, if salt build up was a problem, make sure you replace the thermostats too. It is not a fun job for sure, but rusted or stuck therms will sure ruin your day (and perhaps Motor!)
By the way. The 88 SPL is a great old work horse motor. It does not ask for much, just a little attention every now and then, and she will run forever!
