richw01fishing
- Joined
- Aug 20, 2007
- 2
I have a 1981 35hp electric start and periodically when starting the starter will engage to the fly wheel but then will turn very slowly. If you continue to hold the ignition key on it will actually heat up starter where smoke can come out.
However, you then can turn the key a short time after and the starter will engage and start with no issues. I have replaced all battery cables (+&-) with 6 gage and also replaced postive wire from selonid to starter with no change. Battery is brand new and fully charge putting out 12.5 volts. When testing while starting receiving 11.6 volts at postive lead at starter and ground sensor on engine block.
Again this is periodic and only happens about 2% of the time. Anyone have any ideas what this could be?
