MiloKnezevic
- Joined
- Aug 10, 2007
- 6
Hello there,
These are the photos of 1988 60 HP Evinrude. I was told that it had pistons & rings replaced (pistons looked brand new when examined from spark plug point of view), as well as water pump impeller. It requires a squirt of ether to start up ? I am trying to wean it off. Concern I am having is that it appears to be spitting water out of places I have never seen outboard squirt water. It also seeps oil & water emulsion from the seam above the lower unit. I do not think it is lower unit grease since I just replaced it; this stuff that is coming out seems to be pitch black. Water does come out from the top of the engine as well, through the outlet / hose; that one is warm ? so I suspect it does what is meant to do. The water coming out from the middle of the engine is cold ? feels just like straight garden hose water coming from the muffs.
Can you please examine these photos and let me know if what I am seeing is OK (is that unburned fuel / oil mix) or there is something awry that needs immediate attention.
Thanks,
Milo
Thanks,
Milo
