Finally am getting around to rebuilding the carbs and am glad I did. I found a couple things that definetly needed taking care of. One thing I found was that the small drain hole at the bottom of the air box was completely clogged and the damage can be seen. I am curious though as to where that drain goes. It appears to go into the engine block but where from there?
Next the screw on one of the carbs that covers the jet that sits at the highest position on the carb was completely loose. This to me would let it suck air instead of gas. Which jet is that and what do you think it being loose would do to running of the engine? It was cutting out and I am wondering if this would cause that. In the first pic you can see the screw flush with the carb body and in the second you can see the damage done by not having the drain clear.
