Re: '98 70hp Johnson
61% of your max HP rating - borderline underpowered - could just be "personal weight gain" - or, could be performance is degrading a bit. Still, that motor is just getting broke in good........
Have a tachometer?
Done a compression test lately?
Fuel line holding pressure?
You're not using NGK plugs, are you?
Has your area recently introduced ethanol-blended fuel?
Sometimes a carb rebuild just seems to make 'em happier, for no readily apparent reason. Or that could just be my perception. Or a new primer bulb, something to show her you still care.........
Floatation foam gets waterlogged - adds weight. On a boat that new, you'd have had to left it out in the rain a bunch for that (I think).
power trim?
