Transom repair on Ranger Bass Boat
mkimler
I have a 1973 Ranger bass boat that requires a transom repair. The rotted transom was pretty evident as the motor was actually cutting into the outer skin of the transom from just sitting in the garage. After reading through the forums for a couple of weeks I decided that the Seacast method would be the most economical decision considering im working on a boat that is 34 years old. I removed the cap directly above the transom to expose the rotted transom using a rotozip. This gave me access directly to the transom and allowed for removal of the majority of the wood which is where im at now. However, i seem to have a problem with removing the wood from the top two corners. I only cut and removed the center part of the cap and did not touch the outside edges due to structual issues, so I have very limited access to the wood that resides in these two locations. Does anyone think it would be ok to leave behind what I cant remove and just pour the seacast in? Due to the elevation of the two corners, I dont think the seacast will even get up into those areas. Also, I feel that the majority of the force from the engine is being distributed into the sides and bottom of the transom. I will try and submit a picture to help clarify the issue. Thanks for any help you guys can offer. Have gotten many greats tips from these forums so far!
mkimler
Re: Transom repair on Ranger Bass Boat
Here is a picture of my boat... Not the best picture, i'll try and get a better one uploaded later on. But you can kind of see what I have removed and how the upper corners can be hard to reach.
i think it will be fine, sometimes with a wood replacement i don't worry about that area, unless i pulled the cap off the boat. by the way nice work. i'm sure you read the sticky at the top of this forum on seacast.
mkimler
Hey thanks for the reply! Yep, I did read the sticky and it helped tremendously.
Im hoping to get the rest of the wood removed today and start preparing it for the Seacast pour. I dont want to leave any wood behind and still need to sand the sides of the inner and outter skin to remove any bits of woods or resin. I am a little worried about the outer skin since it is barely even 1/4" thick and there isnt much room inside the transom to reinforce it with plywood. This is such a small bass boat, they actually tapered the inside of the transom where the top part of the transom is about twice as wide of a gap as the lower part. Not sure if that is typical but it really makes it hard to work with and the lower part of the transom wont be as thick. Is this typical in bass boats?
very typical. the top takes the load. i have a transom out now that the outer skin is just over paper thin. it will get several more layers, before the wood goes in. boat wasn't worth the cost of seafoam.
