saltfisher
Thread starter- Joined
- Aug 22, 2007
- 111
Well I went to autozone and rented a compression tester. Went to the boat im thinking of buying, and took all the sprak plug wires off the plugs. Took out 1 plug at a time, started from left side of motor at the top. then right side at the top. Here are my compression numbers. 105-105-105-105-110-105
We cranked it about 6 times each cylinder untill the guage stopped. I think someone told me that it should be between 110-120? My g/f called the boat mechanic at her work, and told him, and he said not to buy it, as it should be around 125-130? So how do those numbers sound? Motor is a 1988 150 mercury black max. 2.5 V6 and i used a OEM brand compression tester.
Thanks
Thanks
