Reduced Revs and Top Speed....
mrgrumpy
I would be grateful for any suggestions. I purchased my first boat at the beginning of the year...1999 Searay 260 Sundancer with a 5.0 Mercruiser 220hp.
Becaused of the appauling weather in the UK the boat has only been used 4 times since purchased. Recently I noticed that the battery wasn't holding charge whilst moored and promptly replaced it for a slightly higher spec battery.
Yesterday we took the boat out for the first time in a while and I found that it would not rev passed 4000 rpm, which was only giving a max speed of 25 mph. From my brief experience I believe that the boat used to run at 5000 rpm, giving a top speed of 32+ mph.
Does this sound like some mechanical issue or could it be in someway connected to the changing of the battery? It does seem a little coincidental....
The only other thing I have done is topped up with fuel.
Thanks in advance
Mark
ziggy
Re: Reduced Revs and Top Speed....
ya need to find out what yer wot spec is. then if it's not reachin wot, here's a pretty darn good list of things to check that dons has provided in the past. thanks dons.....
List of possible causes of low WOT.
Engine Won't Reach Operating RPM. Check
  • Fuel condition. Type and Octane possibly old fuel
  • Propeller pitch or diameter, damaged blades
  • Restricted fuel pickup tube or anti siphon valve Fuel System Test
  • Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
  • Marine growth on hull and outdrive
  • Wrong gear ratio in outdrive
  • Restricted carburetor air intake (clogged flame arrestor)
  • Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
  • Poor cylinder compression Compression Test
  • Carburetor defective, or wrong type.
  • Fuel pump pressure and vacuum
  • Boat overloaded, improperly loaded, or improperly trimmed.
  • Engine Overheating
  • Engine timing and ignition system operation (Full tuneup done recently)
  • Remote control cables and linkage for proper travel to open throttle plates fully.
mrgrumpy
Thanks Ziggy..... I've just realised that i was comparing the performance against the start of the season when the hull was totally clean. People tell me that it not uncommon to see a significant drop in performance, particularly as the boat has been standing in the water for approx 3 months.
