Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
i have added a second battery usig a 0ff,1,2 all switch. what will be the best way to charge at home ? if i use a 2 bank charger where should i put the switch ? i'm thinking to off but dont know if this is the best way.
thanks for info
An on-board charger does not connect to the switch -- the outputs connect directly to the batteries so the battery switch does not enter the equation at all. You can set it to any position but as was suggested, OFF would be the logical choice since you are leaving the boat anyway.
