OMC 4.3 V6 fuel pump question
Status
Not open for further replies.
hogbrains
My 4.3 has an electrical fuel pump and a mechanical pump. It was cutting out so I checked the fuel filter, then the electrical fuel pump. Both were fine so I checked the mechanical fuel pump and it didn't pump. I removed the mechanical pump and there was no where mark on the pump lever so I looked in the block cavity to check the pump rod. There was no rod and no hole for a rod just an empty cavity.
Anyone have a clue???:confused::confused::confused::confused::confused:
Reel Poor
Re: OMC 4.3 V6 fuel pump question
It sounds like someone has had your boat under the shade tree before. :eek:
Gary H NC
If it has an electric pump then the mechanical pump should be removed and the hole blocked off. Were the lines and everything hooked up to it?
TCM
I have a near situation. I am doing and engine swap from a truck due to cracked block. The Mech pump has the monting pad on the bock but the hole / pushrod bore is solid and not drilled. Can this be drilled with the engine in Longblock situe or does it need to be taken down to the block?
Thanks
:cool:
Don S
TCM
Welcome to iboats.
Please, if you have a question, start a new thread. Don't open some old similar thread. Your post will be lost to those that only answer the original post. Which is most of the posters.
rusty one
:)I have seen this pump problem many times before .Never herd of trying to drill this hole .electric pump with a relay grounded threw the oil sender unit.relay runs when engine is cranked then relay off engine oil pressure grounds pump.well something like that
Status
