scott76310
Thread starter- Joined
- Aug 27, 2007
- 8
I think I will do a back flip if someone can figure this one out!! I have a 1996 Glastron with the fuel injected 5.7GS volvo penta engine. On the right exhaust riser is 3 circuit breakers. The biggest one is a 60 amp and it is the one I am having problems with. The breaker only trips when I turn off the ignition. It is very intermittent. It may go a couple weekends with no trips or it may trip once or twice a weekend or it may trip several times in a row. It only does it when you turn the key off!!! Never ever has it tripped while running or turning on (when you would think the load is greatest). I know it trips at the exact second you turn it off because I have the radio running off of an accessory switch on the dash and it kills power to it at the same time. I have no way that I can think of to test it. I know the circuit breaker is good. The only possible thing I could think of that would cause that was possibly a faulty ignition switch that had a short in it when turning off but I left the switch on once and killed it by pulling the safety lanyard by the throttle to kill the engine and it still tripped the breaker. I think everything on the boat runs off of this circuit because nothing works when it is tripped. Please help!
