Does anyone know what the cranking compression should be for a 1980 15 hp/E15RCSD motor be?
This motor has not been run for a few years and the throttle shaft appears to be seized and won't rotate. A few small hole were drilled in the housing above the shaft and WD40'd a few times but it won't budge much. Any ideas how to dissolve this obvious corrosion, or will the powerhead have to be removed to remove the throttle shaft?
Thanks!
Thanks!
