Boats for 3hp outboard
PointBlank017
I just bought a 3hp Sears Gamefisher outboard and now I need to find myself a boat for it.
I'm looking for something portable and I'll most likely end up getting a Korean inflatable. (unless someone can point me towards something better for the same price)
I want something that the 3hp can easily put on plane and push reasonably fast. (with only me onboard) That would probably be a boat around 8 feet long, correct?
I saw some Walker Bay dinghies pretty cheap, but they are supposedly horrible? Any opinions on those?
Since I'm probably going to get an inflatable, I have a few questions about them. First, does the size of the boat matter that much as far as the motor you out on it? I was told that any roll-up inflatable from 6.5' to 8.5' will go the same speed with the same size motor. I've read that inflatables are inefficient and won't go as fast a typical dinghy. Is this true? And are the Korean made PVC inflatables worth buying? Somehow I can't see the glued seams holding up as well as the thermo-bonded ones Zodiac makes. But I can't afford a Zodiac.
That's about all for now.
Thanks,
Mark
WillyBWright
Re: Boats for 3hp outboard
3Hp isn't going to plane anything with a person onboard. The closest you'll come is with a small hard-bottom inflatable.
Dakota47
This will hold up to a 7hp motor
Mischief Managed
3 HP may be able to put a 10 foot John Boat on plane. They plane really easily.
PointBlank017
Dakota, that's a Scorpio right? Are they any good? That might be just what I'm looking for.
Dakota47
There very well made, it planes with me in it (5hp) ,, the boat is 10ft long, yes its a Scorpio. its for sale??
arks
I'm with MM- a 10' Jon boat. Only 70 pounds and it goes right into a pickup bed. Mine planes with 4HP.
PointBlank017
Do they make any 8 foot jon boats?
Also, does a V keel on an inflatable make that big a difference? I've been looking at a few 6.5' inflatables. Some have keels and others don't.
Thanks.
freddyray21
they make 8' jon boats, but I would opt for a 10. The difference with a 3hp is not going to be a lot and the extra 2ft will be nice. The problem you will have is freeboard.
beerfilter
IMO, a 10' jon or one of those little "pond prowler " deals would do fine with that motor .
Another possibility is a 12-15' canoe .
My 4hp Johny will push my little 12' Appleby at a decent clip , but , my 9.9hp Merc will get you there and back without the need to pack a lunch .
That same 4hp Johny will push my 17' Grumman canoe almost as fast as the 9.9 Merc pushes my Appleby ,which is scary fast for a canoe !
If you want to prowl calm still waters , that motor will do fine .
If you want to go any great distance in a reasonable time , and ,have the possibility of racing the weather back to port , you might consider a bigger engine and boat .;)
PointBlank017
I'll definitely look into a jon boat.
If I want to keep it portable, I have too look into a small inflatable. Is an inflatable keel all that important on a 6.5-8' inflatable?
arks
Yes it is- if the engine's able to plane the boat.
Without a keel the boat will tend to skid sideways when you turn while on plane.
PointBlank017
Think a 3hp could plane a 6.5' inflatable?
pwiseman
I had a 3 OMC pushing a 15' Grumman Sport boat. Did ok. It was rated to 5 HP. Threw a 6 on and it went pretty good. They weight about 100 lbs. Similar to a flat stern canoe, but flat bottom and like 44" beam.
PointBlank017
Just thought I'd post some pictures of the motor I got.
I decided on a 7' inflatable from airaquatics. I want it to be portable and these boats seem to be good quality.
