How important is alignment?
outboardnut
Hi All
I'm in the process of putting a whole "new" used sterndrive on my boat. How important is engine alignment. My manual says to check alignment before installing an upper with special tool $*#&$^^*(() that I of course don't have. If I didn't move the motor I don't see why this is neccasary.
Don S
Re: How important is alignment?
How often do you like to pull the engine out and change a coupler that went bad because the alignment was off. due to a loose motor mount, or defective mounts, or rotten transom.
It's early detection of a problem instead of waiting for expensive things to fail completly.
You decide how important it is.
Limited-Time
VERY IMPORTANT For the price of the alignment tool (around $50.00) why jepordize a $300.00 dollar coupler??:confused::confused:
180shabah
It's alot more important than you manual lead you to believe.
HT32BSX115
It's almost as important as checking the oil.
The coupler on my 1966 150 Mercruiser lasted 38 years because the alignment was checked/adjusted frequently. You can destroy one in less than a season if the alignment is out.
Spend the $40-60 for one. You use it every time you R&R the drive!
Cheers,
Rick
Hi All
freddyray21
one of the dealers here will rent you one for 20 dollars a day plus deposit. You can also use a used driveshaft to check the alignment.
outboardnut
Check the alignment it is! Thanks for all the responces.
I have a used driveshaft. I put it in the lower yesterday but it seemed like it was going to be to far down in there to "check" with any of my tools. I'll see what I c an get figured out today.
Don S
The splined yokes (probably what you are calling a drive shaft) does fit very close to the gimbal bearing. The 2 oring grooves are both inside the gimbal bearing.
Make sure your testing shaft isn't all worn out.
outboardnut
Ought O!
I went over the text in my Clymer manual and it says to "take engine to Mercruiser dealer for sterndrive alignment. The proceduce is complicated and requires special tools" LOL
I have the orginal dealer setup manual that came with the boat. It says simply that if the driveshaft slides in....it's lined up.
I have a feeling there is more to it than this?
