First time poster to this site. Lot's of good info. Here's my problem
1979 Mercury 4.5 hp. Serial #5784***. Just purchased. Ran fine first time out, then lost spark. Breaker point was completely pitted and burnt. Replaced the breaker point (gapped at 20 thousand) and the wire leading from the point to the coil as the insulation was cracked and crumbling in serveral places. Also replaced the wire leading from the terminal next to where the "condenser?" connects. Replaced the kill switch as well. Re-assembled the motor. Tested with a grounded lawn mower plug. Had a bright crisp blue spark. Thought all was good. Put into a test bucket, motor fired ran 10 seconds and died. No spark. I have went thru everything with a meter and all wiring checks out. Any ideas? I don't have a clue. Thank you in advance for any assistance you can provide.
