Richard Druckman
- Joined
- Aug 5, 2007
- 3
I just found and joined this site. I've owned a 1990 135 merc. since new . My oil alarm is going off intermittently for about a month now. Stopped for lunch one day for an hour , started the motor and it came on. Another day it was at the end of the day on the way back to the dock. That time restarting the motor after skiing. It seems like after its shut off and turned on again.I pulled the oil pump and plugs to turn the motor and inspect the nylon gear and it's fine.replaced the cap a few years ago and the float under the cap 2 weeks ago. The motor is getting oil and the resoivor in the motor compartment is full. It looks like the oil sensor module. Is there a test or should I just disconnect the oil injection system and mix 50:1 manually. It worked for 17 years with no problem and has 600 hours on the motor.Also if I disconnect the system, can I disconnect the oil alarm and still have the temp. alarm work?Thanks, Richard
