As stated in the title I have a charging problem with my outboard. I realize that this has been addressed before but I seem to be having some difficulty.
To solve the problem I thought it was a simple as testing the rectifier and stator to see which was bad. It turned out that the stator tested bad. I replaced the stator and while i had the cover off I replaced the rectifier. After all the effort the volt meter reads 12.5-12.75 from the charging system. This should be over 13 volts?? Is there something else that I am supposed to check? Or could the stator that i bought be bad? I am a little lost here. Also, after I replaced the components and measured the voltage there is some oscillation in the voltage. The oscillation is small, approximatly 1 volt. In other words I am still reading AC at the terminal leads. Is this normal? I though the rectifiers job is to filter out all the AC and leave just the DC to charge the battery? Anyway, any help or direction would be greatly appreciated.
Thanks,
Scott
Thanks,
Scott
