Breaker Point or Breakerless Ignition (1971 Model 1350)
gidds
Can anyone tell me if the Model Number 1350 (1971) has a breaker point or breakerless ignition. I am going to install a tach and there are two different methods of wiring......does it matter if I try one method or the other?
Ser # 3116298
Laddies
Banned
Re: Breaker Point or Breakerless Ignition (1971 Model 1350)
You engine is breakerless so you will need a alternator driven tach and change the tach wire from the switchbox to one of the yellow studs on the rectifier
Scaaty
See next post..hit the quote button by mistake
Scaaty
Should be a plug in the front of the shifter box...for a tach..or off it BLK/WHT..brown the signal
