Re: Johnson 40hp Igntion problem 1988
don't go cutting anything until you do all the trouble shooting. load test the battery, check the fuse i mentioned. then this.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
then unplug the big red plug, and with jumper cables from postive post on good battery to positive big post on starter. if it starts you are going to have to flood it by turning the red knob on the primer solenoid to stop the motor.
