40 hp yamaha question
sabsab
Recently bought engine, buzzer went off first time out. Shut off engine until buzzer would not come on with key in on postion. Went home had water pump impeller changed out. Went out second time buzzer went off. Went home changed out thermostat.Found spring loaded pressure valve located inside thermostat cover.Can you explain how that valve operates and please does anyone know torque for bolts holding thermostat cover. Have manual on order,has not arrived. Would like to take boat out to see if the buzzer problem stopped. thanks
Ray Neudecker
Re: 40 hp yamaha question
That is the poppit or over pressure valve. Clean it and the washer before reassembling. 6 lbs on the bolts.
sabsab
Thank You, Ray, Will clean and torque. Hopefully the buzzer will stop and I can get back to fishing.
