Slower starter
boneheads
I had the fuse on the motor keep blowing you all helped me find a short thanks. Now right after we fixed the short, I would turn the key once and it would just click, the second turn of the key it would start with no hesitation.
Now I have a fully charged battery, but the starter is slow to turn the motor and wont start. Can anyone Please HELP THX:confused::confused: 1995 40 HP Force
Barnacle_Bill
Re: Slower starter
Your first description is that of a starter solenoid going bad and can cause the second problem. You can verify this by jumping from the + side of the battery straight to the starter. If the starter then works properly, replace the starter solenoid. If the starter still won't work it will have to be rebuilt or replaced. Before you do all that make sure all your battery connection are clean and tight.
JUSTINTIME
Re: Slower starter
sounds like you have a voltage draw
you need to do a voltage drop test
hckrphil
Re: Slower starter
How does it feel when you turn it over by hand?
hckrphil
Re: Slower starter
Just becuase the battery is fully chardged doesn't mean the battery is any good...... I had a motorcycle battery that would charge to 100%. I'd put it in the bike, and it wouldn't have the balls to turn it over.
Got a new battery and bammo, worked great.......Same with my jetskis and my previous boat too..........
Nate3172
Re: Slower starter
I agree with hckrphil. I would do a load test on the battery first or take it down to a local parts store that can test it for you. If it has even one bad cell in it, it will charge up all the way but that cell will also instantly drain the rest of the cells in the battery dead. It will also not provide the cranking amps needed to turn the engine over.
hckrphil
Re: Slower starter
I've also taken my motorcycle battery to Advance Auto Parts and they told me the battery was good.............. yet I was running into the same problem as you. I finally got fed up and replaced the battery, no more problems.
JUSTINTIME
Re: Slower starter
Nate3172
Re: Slower starter
Unfortunately, hckrphil, doing a load test on a small motorcycle battery is not the same as a larger battery such as a car or a boat. The cold cranking amp output is completely differen't. I hear what you are saying, but to do a carbon pile battery test on a motorcycle battery is not a good way to test one and you have to do it at half the rated cold cranking amps of the battery itself, which is not easy with an automotive battery tester and often shows inaccurate results. I use to be a motorcycle mechanic and use to test motorcycle and ATV batteries with a good quality digital (non carbon pile) type tester. With that said, an automotive store such as napa or someone similiar, should be able to test a deep cell marine battery fairly accurately.
hckrphil
Re: Slower starter
Well then, that explains why they told me the battery was good even though it wasn't :)
Phil
